Well went and got my GT last night...a few pics
JH23
26
let me know what ya'll think aboutit ...i have a few bugs in it...cruise dont work...blinkers dont work...but everything else seems ok.....heres a few pics of it and a little info on the motor.
302 Stroker Engine
331 / 410 Horsepower
Engine may vary in appearance
Engine Characteristics : Street / Strip Application Will replace 289 and 302 early and late model engines , (Aggressive Idle)
• Blue printed machined 302 Roller version Block
meticulously machined to accept Stroker crankshaft
• Brand New Scat Cast Steel Stroker Crankshaft
• 4130 Forged Steel connecting Rods 3.25 inch w/ ARP heavy duty Retaining Rod Bolts
• SRP Power Forged Pistons 10 to 1 Compression
Flat Top Performance Pistons
• Sealed Power Moly Rings
• Heavy Duty Double Roller Dynagear Timing Set
• Comp Cams Hydraulic Steel Roller
Cam 2200-6000 RPM Power Range
• Clevite Street Racing Bearings
• Aluminum fast burn Edelbrock RPM cylinder heads
with stainless steel valves, hardened valve locks and
chrome moly retainers and HD Springs • Chrome Moly pushrods
• High Intensity True Roller Rockers
• Melling Oil High Volume Oil pump
• Complete Fel-pro Gasket set
• Factory Replacement Harmonic Balancer
• New Flexplate for Automatic Trans.
(SFI Approved Std. add $300)
• Oil pan, Timing cover and Chrome
Baffled Valve Covers
new wheels and tires....new paint on it....not a bad looking car IMO...let me know what ya'll think
Jamie
lol...m\ya'll..when it comes to quoting horse power and all that...i ARE DUMB !!!!.....i know it has BBK heads....BBK intake....msd stuff....by the weekend i will try ot get more pics of thew stuff...it also has a comp cam in it...i'll look and see what the lift and duration is
Jamie
the cam numbers came off of the box the cam came in...and the numbers on the motor came from the site where he bought it from.....so thats where i got those :)
Jamie
In the third pic, pass side shock tower, on the left in front of the C/C plate, that looks like some sort of electrical connection, ground possibly. What is it?
i have no clue as i got home last night , went to bed and havent looked at it much
Looks like it has a 3g, check it out and make sure its not wired with the stock 10 awg wires, but with a fused 4awg power wire. Just trying to help.
oh i want ALL thehelp i can get...but i will PROMISE you...man you lost me lol
Jamie
