  • 1994 - 1995 Specific Tech
Went 4 1/2 month without changing oil. Oil consumption.
  • Thread starter Thread starter 2003 mustang gt modded
  • Start date Start date Oct 15, 2024
  • 3
First Prev 3 of 3
Admin Dude
Jan 4, 1985
43,306
21,480
234
Box behind Walmart
Dec 4, 2024
#41
  • Dec 4, 2024
  • #41
View: https://www.youtube.com/watch?v=9JD9it6SmB8
Mac131
235
218
53
USA
Dec 6, 2024
#42
  • Dec 6, 2024
  • #42
95 mustang gt 302 said:
2nd gear, 3rd gear. With gear ratio and tire size stock.
I love engines that can make it to 600k, I wonder if 5.0 could make to 500k.
I bet it could if maintained properly and not beat on.
Methodical
1,192
11
59
Clinton, MD
Dec 22, 2024
#43
  • Dec 22, 2024
  • #43
Wolf's Head 15w-50 , what made you choose that oil?
I've never heard of it.
I have a question, if I cruise at 2500 rpm and then go WOT, is that considered lugging the engine?
Depends. What gears do you have and what's the speed at 2500 rpms?
D
dcm0123
5 Year Member
Mar 11, 2017
94
30
28
Dec 29, 2024
#44
  • Dec 29, 2024
  • #44
There are two types of oil warning indicators- low oil level and no pressure.
Ford used an oil level sensor in the oil pan on many vehicles including yours. If this light came on, it is a reminder you need to add oil. As long as you saw oil on your dipstick when checking this, you should be fine.
The other sensor indicates if you loose oil pressure. This maybe a light but my recollection is in your car a gauge is used to indicate the problem. If this indicated you have a problem, you have a major issue. I do not think this is what you were referring to.
There are additional reasons you can have a loss in power which have nothing to do with this. My recollection is a significant change in altitude without restarting the car so it re calibrates itself can cause a temporary loss of power.
You should read your codes and let us know if you find any. If no codes, I would not worry about the power loss unless it happens again.
To verify you have the correct dipstick, change your oil (add 5 quarts) and the filter. Start the engine and run for a few minutes then turn off, Wait 5 minutes and check the oil. The oil level should be up to the full line (assuming you have a factory oil pan). If not, you may want to buy a Ford OEM dipstick. Sometimes the Ford part number is etched into the dipstick if you want to verify that way.
  • 3
First Prev 3 of 3
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
P
Electrical 91 Mustang warning lights
  • Praetorious
  • Mar 4, 2022
2K
Fox 5.0 Mustang Tech Mar 8, 2022
Mustang5L5
