Went to the track tonight
titaniumsc03
42
ohio
Heres what I ran
60' 2.23
330 6.164
1/8 is 9.48
mph 75
1000 12.245
1/4 14.731
mph 93.4
I had a hard time launching cause i was driving my auto camaro too and was having to jump back and forth, I think i had alot better launch in me well see next week, this is with the mods are full exhaust (1 5/8 headers, 2 1/2 or pipe, flowmaster 2 1/2 catback) smog delete, and K&N air filter). What do you guys think?
Russell
Good job. Stick or auto? Coupe or vert? If it's auto., get a stall & some gears & you might see 13's. Manual .... still get gears. What kind of Camaro do you have (& specs)? I'm sure some on here would really like to know.... as I've seen numerous "94-95 Stang vs. Camaro" threads.
As far as launching (you said you didn't do great), just try to get that 60' down a bit.....
its a 5 spd coupe gts, i know i had a better time in it, but I had a hard time launching it after launching my auto, it was throwing me off.
heres what my camaro has
1982 Camaro, 3.73 posi rear, th350 trans with shift kit and 3500 stall, 355 SBC with world sr torquer 2.02 heads, 10-1 comp, .530 lift cam 30/30 cam, 1.6-1 roller tip rockers, mallory ignition, flowmaster exhaust with holley shorty headers, currently a 750 cfm Edelbrock
but I was having a very bad vapor lock problem, it wasnt pulling past 4500 and it was running out of gas(fuel line is 1 " away from header) it ran a 14.6 hopefully ill be able to reroute the line and get in the mid 13s where it should be
Russell
heres the timeslip for the camaro
60 1.97
330 5.903
1/8 9.256
mph 73.49
1000 12.064
1/4 14.60
mph 91.5
like i said it was running out of gas bad, so im planning on trying to relocate the fuel line and maybe put a pusher pump on it instead of the mechanical puller for it
Russell
