What A Mess...someone Save Me From Putting A Carb On My Motor
fat_fox
los angeles
ok so I swapped in a 94 5.0 into my foxbody coupe (original 4 banger) and then decided to use a painless 5.0 efi harness........ the painless harness needs the foxbody-style tfi distributor, so i installed that and made sure al timing was correct... here's my issue.....
. motor will not stay idling now (donor motor was out of my running 94 and ran beautifully)
-has similar symptoms to a bad idle air control sensor....
-might have something to do with me installing a smog delete /egr delete plate and plug...... (capped the crossover tube for now till i can install the plugs in the back of the heads)
Im thinking maybe there could be a difference between the 87-93 and 94-95 sensors in terms of calibration......
- another fun fact..... the pcm is the A9P i believe... (87-89 automatic). the seller swore up and down it would run a 5 speed engine perfectly fine....
problem #2... my starter stays engaged for about 2-or3 seconds after start up (sounds terrible, cant be good)
any insight, tips and tricks would be greatly apreciated!!!! im trying to do all the work myself.... so far ive allready installed most of a complete MM kit for the car and installed Maier racing flares..... and some other body mods..... the whole car has been stripped down to the shell and is in the process of getting re-wired and eventually caged..... fun stuff except for my tuning nightmare
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :D
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 250,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
An improperly wired 94-95 starter will have that problem - see the diagrams below for mini starter...
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-95 Mustang or earlier Mustang with upgraded high torque mini starter.
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
To touch on your ecm stAtement . It will . I ran a a9p in my car until a few months ago . Made almost 600 to the tire with it actually with a 5 speed .
If the starter is wired straight to the ignition switch it will do that. Even though the fender mounted solenoid seems like it would be useless it helps to put the small starter wire on one side of the solenoid....a battery ( 2 or 4 gauge ) wire to the opposite side and the ignition wire in the original location.
I had a mustang that I wired a start button in the center console. That worked well.
If the starter ( small ) wire is running to the solenoid post with the power feed to the starter on the same side it will also engage the starter longer.
In my current car I wired it the way jrichker posted it....and the way I stated earlier in this post.
Good luck with it, man. The 94 engine and sensors are the same...to my knowledge. Could be a lot of things that will make a car do that. On my turbo car it would do the exact same thing. I found out my problems were a bad ground and a loose power wire connection. The car would start and fall on its face....or just crank.
100 mV Ground
0.0V Connections
wow!!!!!!!!! this was the kind of stuff im looking for!! so much helpful info here...... I'll start with the easy stuff first like vacuum leaks since all the sensors worked well before, then go from there... out of curiosity does a 1' phenolic spacer qualify as a intake manifold gasket??? i ask because i might have a leak in that gasket. I got a spacer just sitting on a shelf i thought about installing and need to know if i need gaskets to go along with the spacer......
There needs to be a gasket on each face of the spacer in order to get a good seal.
