Suspension What about these Subframes
  • Thread starter Thread starter from6to8
  • Start date Start date Jan 30, 2025
  • 3
  • 4
First Prev 4 of 4
keel
292
135
53
Seattle, Wa
Sep 24, 2026
#61
  • Sep 24, 2026
  • #61
from6to8 said:
without going back and re reading my own thread let me try and refresh. So the brackets just get fastened via nuts and there's no requirement of the brackets themselves to be welded? LMR did send me the brackets for the 94 and I have the subframes set to go on the 95 at some point befor the EOY.
If the brackets just bolt up then I'll add them myself and I'm sure they'll have to be secured with nuts. When I get the 95 done I'll have him throw those on while he's under there.
You could just throw the brackets on there with nuts but they're not going to do anything until they're welded to the subframe connectors.
from6to8
There's suction so I used that end O_O
1,905
144
94
Sep 24, 2026
#62
  • Sep 24, 2026
  • #62
gkomo said:
No i believe the brackets get welded to the subframes, the bolts are just for the seats to be mounted to.
i think my brackets slip over the seat bolts that stick thru the frame IIRC. Not sure there's a bolt with them, let me take a quick look. Well they don't come with bolts but holes I guess one slides over the seat bolt and theres another hole on the other end of the bracket so maybe both ends need welding....
from6to8
1,905
144
94
Sep 24, 2026
#63
  • Sep 24, 2026
  • #63
oh gotcha
rednotch
I'd like to remain having one chocolate starfish
1,528
726
143
south jersey
Sep 24, 2026
#64
  • Sep 24, 2026
  • #64
There notched for it to be welded to the subframe and bolted to the pan... You can bolt them but I would still weld them, big part of keeping the floor in that area from cracking which is extremely common, probably about 2/3's of the cars I had, have had crack leading to the rocker from the rear seat bolt nearest to it either on the drivers or passenger side. That cross bar braces the area.
Reactions: from6to8
Admin Dude
Jan 4, 1985
43,575
21,740
234
Box behind Walmart
Oct 22, 2026
#65
  • Oct 22, 2026
  • #65
Weld them when the full weight of the car is on the wheels/suspension.
Do not weld them in with the car frame-lifted.
This is also an [excellent] time to look at [all] of your panel gaps and make sure they're where you want them.
Reactions: Shakerhood and keel
from6to8
1,905
144
94
Oct 23, 2026
#66
  • Oct 23, 2026
  • #66
this masterbend shop did my 94 and it was on a lift. I know he knows what he was doing so I guess he had a way to put it on it's weight lol....
on correction, he has several lifts and I'm sure it was on the drive on one. Matter of fact when he did my Terminator's muffler swap I remember him driving it on for that. He has several lifts in the shop.
Reactions: gkomo
  • 3
  • 4
First Prev 4 of 4
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
I hope he gets it
  • All Stock93
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 11, 2026
I think Hot Wheels is trying to steal my identity!
  • LILCBRA
  • Mar 26, 2026
  • Off-Topic Hangout
Off-Topic Hangout Apr 10, 2026
LILCBRA
F
Catalytic Converter Calif Emissions
  • frwgt350net
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 2, 2026
frwgt350net
F
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
