What are the benifits of using forged pistions?
Other than maybe a little extra noise on startup, you won't notice a bit of difference. Some people will say they are better if you are boosting... some people will point out that it's detonation that kills hypers, and it kills forged too :D.
Dave
yes jack, you would need them with boost........it is a protection factor, if you want to build a motor that will last a long time on boost, then go forged. If you are building a fast motor with out boost or nitrous, then you can go with the hyp. piston's........hotwheels
forged pistons arent bullet proof... detonation can still kill forged pistons but it'll take a lot more than it does to kill hyper pistons. Go for the forged pistons. Just a little extra insurance so you dont blow anything.
I would never put forged pistons in a stock block unless I was doing a basic rebuild that required to bore alittle to clean the bores up and got them for almost the same price a hyper. You will crack the block before you run into an piston problems with a good tune. BTW Chris on TM is making 600+RWHP with a stock bottom end.
