Mach 1 what are the best mods for a mach1?
04mach1 said:
Hi yes i am a proued owner of a an 04 azure Blue Mach1 5-speed. I was wondering what are some of the best bolt-ons for the car.
Sticky tires (Nitto or BFG Drag Radials)
Gears (4.10 or 4.30's)
Exhaust
Cold air kit (K&N/MRT/PHP)
in that order... :nice:
yes axles for sure, my friend was launching @ 3500rpm with Nitto DR and snapped his axles.
My list is has follows:
Moser 31 spline Axles $229
FRPP 31 spline Trac-Lock $189
FRPP 4.10 or 4.30 Gears $139
Now you can launch @ 6000 rpm without worries,
Good Luck
myrez99 said:
Angus,
Shouldn't he upgrade his axles and pumpkin before putting sticky tires on? I've heard of too many Machs with broken axles because of DRs. :flag:
Yeah, I left-out the axle upgrade due to a momentary lapse in judgement. :bang:
I did the 4.30's/31-spline Superiors/31-spline Eaton/T&A cover girdle at the same time, and would recommend a similar set-up for any Mach 1 owner who's going to frequent the track more than a couple of times per year.
(I always planned on some high-rpm launches, with slicks in my Mach's future this fall... :banana:)
ok ill answer this since ive done tons of them
GEARS AXLES AND POSI!!! nothing less then a 4.10
Chip!
long tubes x pipe and cat back
Drag radial or slicks
amazon air box (yes we can mod it for the shaker also)
that right there will be a solid mid 12sec. car
