I agree with everyone, The rods are the weakest part of the moter, our shop car is in excess of 600 rwhp with a stock motor, but I would not reccomend for anyone to try it.
We tell our customers 450 with a good tune is a nice safe number.
If you plan on staying N/A there is no need to replace the rods unless you opt to do something lighter to build a nasty little n/a motor.
If you have other concerns in driveline strength the driveshaft itself is weaker than any other part of the drivetrain.
In instances of drag racing, (with a sticky tire) the stock clutch can easily out handle the stock driveshaft, next would be the clutch then the input shaft in the trans, then at aome point you will realize a weakness in the side gears of the differential, they will have a tendenciy to crack if you opt to hole shot or wheel hop the car regularly.
Don't let this talk you out of a car, in stock to mild form they are awesome and truely reliable, I am just giving you the list of failures in order, that we have logged in the two years we have been racing our cars. If you do not drag race or opt to run a sticky tire you will find that everything will live a long happy life.
