- Dec 3, 2005
- 372
- 0
- 0
Hi,
I recently had my car retuned for the summer as well as the addition of a catted x-pipe (SLP) The results of the tune were surprising to me, in that I actually picked HP but lost a lot of torque. I know x-pipes tend to sacrafice torque for HP, but the loss was bigger than I thought it would be. Before I go on I will list the variables: The biggest influence on my dyno numbers is probably that the initial tune was done on a 50 degree day, where as the most recent tune was done on a 90 degree day. I am sure this is responsible for most of the descrepancy.(But I want to hear what you guys think)
On the cold day tune (stock midpipe, 50º) my numbers were: 425HP/405TQ
On the hot day tune (SLP X-Pipe, 90º) my numbers were: 437HP/385TQ
A/F was mid to high 11's across the rpm range.
These numbers are peak numbers, which wouldnt be that bad except for the fact I lost a lot under the curve. I lost 20 lbs/ft of torque across the board under the curve, until 5000 rpm where the numbers from the original setup and the new setup intersected. In some places I lost as much as 40 lbs/ft down low. I also lost about 20 hp across the board under the curve until 5000 rpm where I actually started to make more power. My question is how much of this loss is related to the tune vs. the weather? What aspects of a tune most influence torque?
On a seperate note; the car sounds freekin awesome with the SLP pipe and Borla Stingers.
