callys Member Oct 14, 2005 76 0 7 Aug 21, 2007 #1 Aug 21, 2007 #1 I want to box up the factory 14 inchers on my mach 1 and go to Magnum 500s. I plan on using 15x7s all around, what backspace are you guys running? Or what is the standard one to run? Thanks
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Aug 21, 2007 #2 Aug 21, 2007 #2 generally a 15x7 wheel has a backspacing of 3 3/4 - 4". some as much as 4 1/4".
G grego37 New Member May 12, 2004 576 0 0 Fresno CA Aug 22, 2007 #3 Aug 22, 2007 #3 if its an option, you can go wider on the wheels, the 69-70 mustangs have lots of room for big rubber
callys Member Oct 14, 2005 76 0 7 Aug 22, 2007 #4 Aug 22, 2007 #4 Trying to keep a fairly stock appearance as the car is all original and all stock, thanks for the info rbohm.
