Platonic Solid said:
What's involved in converting my current stock 9" to a Detroit Truetrac?
Is this a DIY project (for a person with basic tools and no machine shop equipment)?
I only see one online reseller listed on DetroitLocker.com: "
Power Train Truck And Auto Parts". Are these prices about right?
Thanks
It can be done if you are mechanical minded and patient. There are several web sites that detail swapping an open center for a locker. You should have access to a dial indicator and stand to check backlash--you can get one for around $30 from Summit.
Basically remove the axles and then the chunk. Wipe off the lub on the gears and using marking compuund (or heavy grease) run a pattern of the gear mesh. I wrap a rag around the pinion to creat drag and push/pull the pinion. Do this several times and compare the pattern to some of the patterns found in a shop manual (good reference) or some of the patterns found on the internet. Taking a good before photo of the pattern (coast and drive) would be good should you need to ask us questions later. Set up your dial indicator and measure backlash. Should be in the neighborhood of .008. Don't worry if it is more as normal wear and tear will increase the backlash.
Next, check out how the adjusters work before disassembly. Mark the "main caps" to make sure you put them in the exact same location. Then it is time for disassembly.
Remove the 4 main cap bolts and remove the cap and adjusters. Remove the ring gear assembly. You will not need to mess with the pinion so leave it bolted up. This fact makes it easier for a newbie to work on a rear. Next remove the 10 bolts of the ring gear and carefully press it off using a soft hammer or some 2x4's to prevent damage.
As far as the True Trac goes, it is fully assembled except you should purchase new bearings--the size is based on the case. The new bearings need pressed on. I found that I was able to drive them on easily with the properly sized socket. I then checked the ring gear for burrs and then installed it on the True Trac. A little rubber hammer action helps. Clean the 10 ring gear bolts, add locktite, and tighten them to torque.
Put the new posi section back into the case and install the maincap, bearing races, and the adjusters. Make sure that the adjusters move freely when the maincaps are torqued to 20 ft lbs. You can use screwdrivers or I made a spanner wrench just to turn them, but in general, they should move freely. Turn the adjuster that moves the ring closer to the pinion until they meet. Then turn the other until it is bottomed out too. Adjusters shouldn't need major torque to do this--I typically use just hand pressure. You should be able to spin the pinion which will turn the ring gear. It should seem a little tight, but this is seating the bearings.
Next move the adjusters so that the ring gear moves slightly away from the pinion. Using the dial indicator, measure the ring gear runout (no more than .003). Next set up your dial indicator and measure backlash. Moving the adjusters, set it to .008 and be sure to test it in several locations around the ring. Next run a pattern like you did when you first removed the chunk and compare. It should llook like what is in the books and should be comparible to what you originally had. You may have to vary it a little, but not much to look good.
Once satisfied, you wil want to remove the main bolts one at a time and put locktite on them, reinstalling them immediately before moving to the next one. Torque main caps to specs. You will now need to create some preload on on the ring gear bearings by tightening both adjusters tighter, about one hole or so which will further squish the bearings. Recheck the backlash and pattern and adjust as necessary. Locktight the adjuster lock bolts and reinstall.
Reinstall the chunk and axles. You can use a new gasket or some black RTV will work fine too. I like to fill my rear through the axle before it gets installed.
Be sure to take lots of digital pictures (before and after) as they will guide you and will allow others to help should you have problems.
The prices on that site are very nice!
