What brake parts should I get at salvage yard?
Aug 11, 2008
254
I am going to be doing a 5 lug conversion on my 91 LX. I will be going the salvage yard route, and have a few 94-04 Mustangs to acquire parts from. What I need to know is, should I get the 94-95 spindles and backing plates, and get the calipers from a 99-04? Thanks
Awesome :nice:. Thanks guys. So I'll get the 99-04 rears with the 94-95 soft lines, and ranger axles. I was trying to do do a little research, on the anti moan brackets, and some people are saying if you use the NRC brackets, you don't need them. Can anyone confirm this?
I would get them. It's hit or miss if you need them. If you are stripping the rear brake parts you might as well get them.
BTW, you can use all 94-04 rear brakes. They are the same. The only difference is the axle because the housing is wider on the 99+ cars.
So 94-04 rear brakes, dust shields, calipers, 94-95 rear soft lines, north cobra rear brackets
up front 94-95 spindles, 99+ calipers
Also try and snag an entire 94-95 v6/gt MC and booster setup
