What cam for my set up
i have a stock 1991 302 with 125,000 miles and i really want to put a cam in. what cam do you think i should get? i was thinking of putting in a F-cam. good or bad idea? in the future i plan on putting afr 185 heads and a trickflow intake.. as of now the car is a 5-speed it has 410 gears, full exhaust (mac all the way back) 70mm TB, pullies, no smog pump and i have a FPR sitting in my room.. any input would help me out.. Thanks
I'm getting ready to install the f-cam myself, but I'm waiting until I get a new intake first to go along with my ported e7te's. You should probably wait on the cam until you decide which heads and intake you are going to go with. The f-cam would be too much for a stock head and intake setup and the car would probably not run very well. I really wish I had just got a custom cam instead of the frpp cam because that seems to be the way to go.
well the only reason why i'm thinking of putting in a cam is b/c i need a water pump, timing chain, and timing cover gasket. so i figure since i'm their why not a cam. i plan on adding heads and intake by the end of the summer.. i was thinking afr 185cc heads and a trick flow intake how does this F-cam sound with this combo. i'm got the cam brand new for $50 in the box.
