What cam for SN95 331 AODE?
scarless
175
Here's my combo, what cam? Remember it's for an AODE!
331 Stroker 10:1 cr
SN95 Cobra \w ported lower
70mm Throttle Body
80mm MAF
30# injectors
GT40P heads ported 1.85/1.46 Manley race flow valves
2800-3000K converter
AODE \w shift kit
4:10 gears
Crane springs, good for .560 I think. Heads arn't done yet. I'm hoping they flow about 210/170 at .500. I'm hoping to not mill the heads much, if at all. I don't want the compression ratio much over 10.0:1.
I currently have a Steeda #19 I could use, but I was looking at the CompCams grind 35-351-8 XE270HR 114 degrees \w .512/.512. I also have 1.7 cobra rockers. That would put the lift in the .545 range. The 35-324-8 XE270HR grind for 1.7 rockers has the same specs but on 112 degrees. Neither say that they will pass emmissions. All I need is to get the engine in and have it fail emmissions, then have to pull the cam.
