What cam should I use?
  • Thread starter Thread starter 91stangy
  • Start date Start date Jun 19, 2006
9
91stangy
116
  • Jun 19, 2006
I could use some advice on what Cam I should I use. I have a pretty much an all stock 302 motor. Edelbrock Preformer intake manifold, the usual cold air, nothing eleborate. I've been told to stay with a Ford cam, like the E303 or the B303. Most are saying use the B cam. But I'm open to suggestions so please... suggest becasue I'm lost in this area, ha. I am not quite sure what kind of power I'm looking for so Im open for anything. Thank you.
just4bob50
504
Pa.
Jun 19, 2006
  • Jun 19, 2006
Well if you plan on doing heads later on you might as well wait till your to do them also. If your going to add boost stay away from the B-CAM. I've read that it bleeds off alot off boost, but it is good for (NA). I know the E-cam is a good all around cam for what ever upgrades come later. But if your changing your cam hoping for a huge power gain while still running the stock heads dont count on it. Most people i know that change the cam with the stock heads do it more for the sound of the idle. If that is what you are looking for and your not going to boost your car I know the B-cam sounds wicked with the stock heads still on. My friend had long tube headers, off road X-pipe,and 1 chamber flowmasters and his car sounded deep and loud with the stock cam in, but when he did the B-cam it completely changed the sound of his car. The car only runs mid 13's but sound like it would run alot faster when its ideling.
J
jjd975
4,236
louisville,kentucky
Jun 19, 2006
  • Jun 19, 2006
Its hard to beat the TFS-1 IMO. Its better than the Ford cams IMO.
The Ford cams are OK but you would really be making a mistake if you limited yourself to just those few cams when ther are so many options.
JChalfan
551
Bellevue, WA
Jun 19, 2006
  • Jun 19, 2006
91stangy, what gears do you have? 5-speed or auto?
The only non-stock cam I have run was a Ford E-303, with 1.7 roller rockers and cast-iron GT-40's. '94 cobra motor actually.
The cam made good power especially mid to high rpm's, and the idle sounded awesome. Car guys always turned their heads when I started it, surprised to see a stock-looking LX Fox idling like that.
I think I heard the B-cam has a rougher idle than the E cam. I'm sure someone will correct me if that is wrong.
Like just4bob said, don't expect huge power gains with the stock heads. If you put on a set of GT-40P's or some ported E7's, those and the cam would really wake up your car.
Jeff
9
91stangy
116
  • Jun 19, 2006
I have 373 gears, and it is 5 speed. I have done the exaust with short tubes, Mac pro-chamber, and flows on the back. And you're right I would be mistaken if I were to limit myself to these few Ford cams. I'm open to any suggestions about any cam set up, wether it be Crane or Comp. I understand I should be saving for heads also, but money is an issue and in a sense Im just looking for a few more hp and a nicer sound (I know there wont be a huge power increase, but every bit counts). Plus it's going to be a birthday gift lol. Heads will come later (keep in mind Im thinking of 351W heads), and maybe even a SC(much farther down the line).
Hopefully this helps you, help me lol. Thanks again.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jun 19, 2006
  • Jun 19, 2006
Stock headed car and cam swap is ALOT of work for very little return..I would save the cash. Your talking maybe 10hp and a little idle bobble for 6 hours worth of work (maybe less if you're experienced).
Stroked88
42
Jun 19, 2006
  • Jun 19, 2006
I really like my Crane 2031 cam. I installed it on my stock short block with a set of TFS Twisted Wedges and an Explorer intake. Really woke the car up. I plan on getting a super charger after I get my car repainted.
just4bob50
504
Pa.
Jun 19, 2006
  • Jun 19, 2006
To some people.. how the car sounds when it idles is just as cool to them as the guy's who need the loudest exhaust to set off car alarms. Ya its a bit of work but you wont regret it. If I would have known my car would have sounded as good as it does now with the cam in it I would have done it long ago. Hey if some one else is buying the cam all you got to do is buy some gaskets, and fluids. I would consider a new timing chain since it has to come off anyhow.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
