what cam to buy
  • Thread starter Thread starter reyesjo
  • Start date Start date Jan 26, 2007
R
reyesjo
66
  • Jan 26, 2007
Here is what I got. Its a 1966 Mustang with a 5.0L from a 1989 mustang, its has the basic stock motor with 3:55 gears, and a T-5. Also I have the Trick Flow twisted wedge heads with springs good for .600 lift, Trick Flow Intake "Track Heat" 1.6 RR, 75 mm MAF with 24lb injectors, 70mm TB.. What would u guys recommend for a CAM?
Stage I, Stage II, or another brand what do u think?
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jan 27, 2007
  • Jan 27, 2007
Calling a cam manufacturer and giving them your cars weight, gear, trans, info, block, heads, compression ratio, valve relief c.c. ,final gear ratio, tire height, and a slew of other things that will give you an accurate answer.
57fairlane
560
Oakwood, GA
Jan 27, 2007
  • Jan 27, 2007
stage 1/2? what are those?
It all depends on what you want to do, obviously a custom is going to be the ideal decision based on performance but it doesn't sound like you care about spending $300 for something all out.
Cheapest way would be to find a used TFS stage 1
A xe274hr would probably want a little more gear but in a stick with a lighter than foxbody car, it would probably put down close to 300rwhp when all said and done.
So there are other options out there, it just depends on your budget and what you want to do with it.
R
reyesjo
66
  • Jan 27, 2007
TFS STage I or II
I was thinking about buying a TFS I or II, just wanted to see what you guys think.. and recommend..
here is a link to my mustang..
what do u guys think?
http://www.cardomain.com/ride/2215774
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 27, 2007
  • Jan 27, 2007
that is a pretty mustang. As far as the stage 2 cam goes some guys have gotten away with using it others have not without notching pistons. The stage 1 will work nicely for sure.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
