Here is the thing , guy whi help me with my Stang is mechanic ONLY for Mustangs , he build a lot fast Mustangs , he have 94 Mustang 374 with blower run 10s on 1/4 , he is like I don't know how to say , he know everything about Mustangs except this my problem , we work in last 2 weeks over 20 hrs and still didn't find whats wrong, he try swap stuff from his Stang onto my Stang, I have a lot spare stuff plus I buy tons new stuff like
I thisnk this is like 100th time I said , I check , clean and change EVERYTHING
ECT , IAC , IAT , MAF , TPS , Ignition Module , All spark plugs , wires , distributor cap , rotor , INJECTORS , air filter , fuel filter , fuel pump, O2 sensors , PCM , CCRM , everything , fuel pressure is 38 just like before , compression is good (137-150psi) timing is like before , everything looks normal but still runing too lean , looks like misfiring, I mean everithing , there is no vaccum leak between Upper and lower intake and lower to heads , I don't know what to do
I didn't check vaccum with Vaccum tools , I check for vaccum leak but no leak
What else I can do
He said something tell computer (PCM) to lean down
BUT There is no CEL code NON we try like 50 times NO CEL CODE's
