mcheck your thermostat housing to see if it's leaking...i had the same problem and it drove me NUTS. found out the chrome t-stat housings are usually not perfectly flat![]()
RTV. Also, the chrome housings usually leak from the plating process. Ask me how I know...Went with a regular cast one, and no problems.
ditto. Only thing, i need the chrome housing, only because it has a 3/8 threaded insert for my MK8 fan set up regarding the sender. If not-I'd junkit and run the stocker.
i have been having some trouble getting rid of water leaks. i need an idea on what to use.
