What compression are you running?
  • Thread starter Thread starter stock50LX
  • Start date Start date May 26, 2004
stock50LX
Curmudgeon
1,858
University Place, WA
May 26, 2004
  • May 26, 2004
The pistons I purchased are going to give me 9.7 with my current iron heads. I am now second guessing my decision and wondering if I should and could have gone higher? I want to be able to drive the thing on pump gas. I have no plans for any type of power adder. The engine is a 351 soon to be a 357.
408stroker5.0
The world would be a better place if all males jus
Mar 10, 2004
639
Bonnyville, Alberta, CANADA
May 27, 2004
  • May 27, 2004
You can get away with anything lower than 11:1 on pump (supreme)gas. Just don't lug the engine.
bhuff30
6,037
35
129
Olathe KS
May 27, 2004
  • May 27, 2004
408stroker5.0 said:
You can get away with anything lower than 11:1 on pump gas. Just don't lug the engine.
Probably with an aluminum head and premium you could, but not on an iron headed with 87 octane.
9.7:1 is plenty low to continue using 87. I might go up to 10.3-10.5:1 for pump gas, but I would be listening carefully for detonation and hoping I didn't have to retard the timing a bunch.
A tiny bit of extra compression isn't going to give you that much of a noticible gain in the real world. Error on the side of caution.
Can you mill the head much on a 5.0? If so, you could mill it down a little instead of getting different pistons.
408stroker5.0
Mar 10, 2004
639
May 27, 2004
  • May 27, 2004
Notice I put Supreme Gas not Regular Gas which is 87 Octane. You could not run 11:1 on 87 octane.
Supreme which is 91 Octane is usually enough but a little octane boost would be a good idea.
5.0 HOtrain
2,247
New Hampshire
May 27, 2004
  • May 27, 2004
I run 11.25:1 with aluminum heads and super. Have yet to drive it on the street, but ran fine on the dyno, first test drive hopefully this weekend
mike.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • dan50
  • Jul 18, 2026
dan50
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
