what determines your shift pattern???
  • Thread starter Thread starter Foxfan88
  • Start date Start date May 11, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 11, 2005
  • May 11, 2005
is it the valve body???
if i got a new semi manual VB for my AOD, would i get spots for all 3 gears and a drive setting and of course N R and P???
Can someone give me the basic run down of valve bodies???
hllon4whls
BANNED
2,567
Covington
May 11, 2005
  • May 11, 2005
You can get a valve body with detents for each gear (D21). OD is activated by an electric switch.
Dont know if you can get this for a AOD, but for a 3 speed tranny, you can get a reverse manual valve body which changes your shift pattern from PRND21 to PRN123 and makes the transmission fully manual shift.
D
davs5.0
921
windsor,ontario,canada
May 12, 2005
  • May 12, 2005
Lentech makes a valvebody for the aod that makes your pattern P R N 3 (OD spot) 2 (D spot) and 1. You turn the OD on with a electric switch. If you leave the shifter in OD it shifts automatically up to 3rd and then you just flip the switch for OD.
T
tjm73
2,418
Rush, NY
May 12, 2005
  • May 12, 2005
The shift pattern is enginered into the valvebody.
AOD (stock) is P-R-N-OD-3-2/1
AOD (LenTech) is P-R-N-3-2-1 with OD being engaged/disengaged by a switch
C4/C6 (stock) is P-R-N-3-2-1
C4/C6 (aftermarket reverse pattern valvebody) is P-R-N-1-2-3
You would not get a detent for all three gears plus the OD. It would be just like stock with OD activated electronically.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
