Im putting mine on now and I remember you all were using different torque specs then stock, i think. What was it?
BlueOvalStangGT said:Ok sweet, for the bottom bolts, did you use RTV sealant or teflon tape or ???. Thanks guys,I think i might get this engine in a day earlier then expected!
BlueOvalStangGT said:For the bottom ones?? Are you sure??
Maybe the gold stuff was anti-seize. Now I'm confused.
Either way, you can use thread sealer on everything and be good.
CManT1914 said:EDIT: Saw David's post after mine. Is the white stick thread sealer or antiseize? I used the white stuff on all mine. I don't even remember now.![]()
GRGT1994 said:I was paranoid, so I used the ARP brand moly lube and sealer (sealer on the bolts that hit the water jackets, lube on other). That stuff is expensive!
