What differences in 351 with 9.48 vs 9.503 deck height?
  • Thread starter Thread starter Rookie71
  • Start date Start date Jan 8, 2007
R
Rookie71
28
  • Jan 8, 2007
What things will need to be address when buying parts to have a 408 stroker put together when using a '69 9.48 deck height block? Does this impact the intake manifold. I assume a stroker kit needs to be different to accomodate the shorter height? Right wrong? other things?
Thanks.
F
FullAuto
157
Midwest City, Ok
Jan 8, 2007
  • Jan 8, 2007
You basically just need to brand shop and compare overall compression heights. Some kits will vary a few thousandths. You might just end up with a kit that is .02 out of the hole. Check with your machinist to see what will be an acceptable range.
But for example, I know the short rod 347 kits are becoming popular because of the internet myth that the long rod version burns oil. You can thank the guys that can't properly assemble a shortblock for that. So CHP offers a 5.315" rod version of the 347. Scat's version uses a 5.325" rod. They use the same piston. The CHP version comes out to 8.190" deck height. The Scat version comes out to 8.200" deck height.
I don't think you're going to be able to find a specific kit for a .002 shorter deck though. If you really wanted to spend some cash, you could always get a custom piston.
86nu
94
Birmingham, Al
Jan 8, 2007
  • Jan 8, 2007
I thought the two deck heights were 9.2 and 9.5
F
FullAuto
157
Midwest City, Ok
Jan 8, 2007
  • Jan 8, 2007
9.2" is a Cleveland. 9.5" is a Windsor. In reality, the '69-'70 351W was 9.48" deck height. The '71-up was a 9.503". Just like our 8.2" deck 5.0s are 8.203".
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
7K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
