That would be nice! I need to get down to the track. I just switched tires from my 295 BFG G-Force KDW2 to the 315 Falken RT-615. I would spin through second at the crappy track in TX with the BFGs. Best I had at the time was a 14.2 with the spinning, and crappy launch. That was before gears, pullies, headers.
Here's the current mods. It's a fancy list I know, because I copied and pasted from my main list I use to keep track of specifics
BBK Polished Ceramic 1-5/8" Longtube Headers
BBK Offroad H-Pipe
Magnaflow Standard Catback (2.5" with 3.5" Tail Pipes)
Dragon 75mm Plenum
Dragon 75mm Throttle Body
Steeda Cold Air Intake
Mach 1 Grille Delete and Chin Spoiler
Steeda Sport Springs (1.25" Drop)
Tokico HP Series Shocks and Struts
Steeda Aluminum 4-Bolt Caster-Camber Plates
Steeda Tri-Ax Shifter
Maximum Motorsports Full Length Subframe Connectors
Ford Racing 3.73 Gears
Steeda Underdrive Pulleys
I have MM LCA's in the closet I'm waiting to put on, along with the WB.
I definitely understand the reason to go the cam route instead of the cosmetic one. The only reason I would choose cosmetic is it's cheap, and it's something I had already wanted to do. A couple hundred, and then save the rest, or dump all $1500 into cams. If I had a little more cash I would choose cams in a heartbeat and not give 2 s**ts about the front bumper. It's still up in the air but I'll probably end up passing up on both ideas for now lol
I need to sell some of my tournament grade paintball stuff from when I was in the Army. Could probably make a good $700+ off that. I rarely play anymore.
