95Vert383AOD
I have to agree with bentley.... Toss a 500+hp motor into a mustang with a tranny...HAHAAA do you really want to be the guy who breaks down to/ from or at the track??? I personally beat the piss out of my mustang. Cut you have to build the car up....it adds up!!! A fuel system the right way will cost you $2000...Aeromotive pump $300, Pre pump and after pump filter $120 each. The sump fuel tank....$20 for EACH elbow...braided line runs about $6-7 per foot. I have a 255lph pump sitting in front of me....because i thought that would be enough with stock lines. Stock lines were enough to make my car get 265 hp @ 4000rpm and 497.3 RWTQ @ 2000 rpm. My 383 with stock fuel lines would make the pressure drop 15-20psi when i revved the engine. My engine was drinking fuel out the rails faster than my 255lph pump could get it there. BTW i run only 36lb injectors, No power adder. Take a look at a fuel line on a 500hp Vette bet they're alot bigger than a stock Mustang. Hell my friend is restoring a 1966 Pontiac Catalina. The fuel lines on it are nearly twice the size of a mustangs and it was a 400ci motor making nowhere near 500hp. But i digress....i built a fuel system all Aeromotive and i even made my own Sump tank (to save money) and it still came to around $2000+. Fittings alone were a few hundred. Im not a fan of piggybacking fuel pumps thats a bandaid for a better pump and bigger lines.
You do a budget 500+ hp car and chances are youll be getting towed home and the Vette will be driving home. Pinging at redline isn't a good thing.
Do it right or don't do it at all noone likes to buy engines or aftermarket race parts twice.
