What do i need to....
Keep in mind - those stockers are usually running long tube headers with a good exhaust system, 4.10 or 4.30 gears, either slicks or drag radials, suspension mods to help plant the rear (drag shocks, no front sway bar, adjustable control arms, etc.) and they launch and shift the cars like you can't believe - very low 60 ft. times given the power of the car. So, unless you have those mods, you're gonna go slower. But the potential is there if you learn to drive and dial in the traction. Doesn't take any more power than stock to run the times you want to run - it's just getting every bit of that power to the ground.
