What do u think i will run.
bigap15
115
Ok guys. Car wars is march 19th in clay city, kentucky. I'm thinking bout going and seein what i can run. im hoping to have this stuff done.
94 gt, 5 speed, king cobra cluthc, 3.55 gears, cold air intake, trick flow street heat, timing advanced to 14, mac unequal length headers, off road h pipe, flowmasters dumped, smog delete, a/c delete, march underdrive pulleys, hurst short throw shifter, Nitto drag radials on stock 16" wheels.
Im gonna try to also get my heads ported and 3 angle valve job with upgraded springs and 1.7rr, maybe gasket matched, and have the street heat gasket matched, 70mm throttle body, 76 mm mass air with 24lb injectors.
what should i run on the first setup and what should i run with the second setup added on. Im looking to get maybe high 13s with the first setup. I guess i would be okay with high 13s, what should i run.
just a suggestion. scratch the maf, tb, and injectors off the list. add that money to the money you would spend on machine work. put that money towards suspension parts, or start saving for some gt40/p's and a cam. for comparrison i went 14.2@99 with the cobra intake and exhaust. i went one time with my current setup and got the time in my sig. im shooting for low 13's next time i go. im sure i could get high 12's if i was not on street tires. even lower when i get rid of the stock suspension but that wont be for a few months. as far as time you will run, if this is your first time going, i would not count on gettting 13's.
What if i get gt40y heads and the trickflow intake and some mac p headers, and ill wait on the nittos and the tb and stuff. I should be mid 13s then shouldnt i. Hopefully i find a job to fund all this.
