What Do You Guys Think About This Crack?
  • Thread starter Thread starter redneck15431
  • Start date Start date May 11, 2014
R
redneck15431
83
May 11, 2014
  • May 11, 2014
About 5 years ago I had removed my entire interior to have subframe connectors and upper and lower torque box reinforcements welded in. I currently have my interior out for some surface rust on the passenger side floor from water that leaked in. I completely forgot about this crack, but at the time, I had just drilled out the ends of the crack to keep it from spreading. This is behind/underneath the rear seat BTW. This is the worst crack in the entire car. There are a few other much smaller, much more mild cracks. There is a good bit of separation there, so do you guys think it can be welded up with no problems? Or should I just leave it be? I have no welding experience, so I don't know what to do with it. I'm assuming the spot welds around it are from the upper torque boxes which had began separating. What do you guys think about those?
CarMichael Angelo
8,909
234
Birmingham, al
May 11, 2014
  • May 11, 2014
Dude that is a classic case of the torque box getting ripped out of the floor and the resulting stresses that are occuring because of it.
You HAVE to have it welded. You should STOP driving it until you do.
You will continue to tear the car up just by driving it, until it becomes so major (if it's not already) that the car will require extensive surgery (i.e. frame work) the get it where it'll go down the road again.
And,...(judging by that pic) if there are supposedly torque box reinforcements done to that car,....they forgot to do the uppers,.............entirely.
R
redneck15431
83
May 11, 2014
  • May 11, 2014
I have upper reinforcements welded in. So should I have everything welded with a solid bead underneath? Or just weld up the crack and call it good? I have been underneath the car and I haven't seen any damage to the frame or anything else. I really don't know which direction to go with it. I'm pretty mechanically inclined, but limited on resources such lifts, etc. And welding. Anything else I should be on the lookout for? I would really like to find somebody who is familiar with the structural aspects of these cars to work on it.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
May 11, 2014
  • May 11, 2014
This is not a crack you want. Just leaving it was BAD idea. I would have it welded from any and all sides then reinforce the areas as much as possible.
Unless you like things falling off the car and water coming in to rust the rest of the floor and structure.
rbohm
6,698
550
204
tucson,az
May 11, 2014
  • May 11, 2014
weld teh crack, since it is sheet metal you will need to do it with tack welds to avoid warping the metal. then reinforce the cracked area by welding new metal over the crack, preferably on both sides so the crack is sandwiched.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 11, 2014
  • May 11, 2014
As others have said, you need to get that welded and reinforced ASAP. I wouldn't want to see your control arm get ripped out.
R
redneck15431
83
May 11, 2014
  • May 11, 2014
Well, fortunately I don't think the crack has gotten any bigger in the last 5 years. It appears the same as it did back then. It was dumb of me to leave the crack go, but at the time I was not concerned with the preservation of the car as I am now. I am more than willing to tackle this job myself, but I just need to know what to do and what to look out for. You gotta learn somehow, right? Structural repairs are probably not the best way to learn for a beginner, but as I have grown out of my wild teenage and early twenties ways, I am more detail oriented. I know what a good weld and bad weld looks like, I have just never done any welding myself. So is this something that is very fixable, or am I just wasting my time on this car? Does it really appear that bad? Money is not an issue, however, I do not want to dump money and time into it and not be able to "enjoy" it, you know what I mean?
Thank you guys for your input so far. I don't necessarily have a trained eye for this kind of thing. So any more help is greatly appreciated!
R
redneck15431
83
May 11, 2014
  • May 11, 2014
What would be the permanent fix for this issue? As I'm doing research, it seems as if welding/plating would result it cracking in another spot.
CarMichael Angelo
8,909
234
Birmingham, al
May 11, 2014
  • May 11, 2014
The fact that you cannot weld is not relevant here. You need to get it done though. The uppers cannot be reinforced or there would be evidence of it look at this pic:
Look at the floor where your cracks are . Had your torque boxes been reinforced, there would either be a plate bolted there, or (as in this case) evidence of the welding burn through from the bottom.
Plating and welding is the permanent solution. As Rbohm has detailed, welding the crack closed, (which will be a giant pain in the ass on rusted galvanized steel) then welding a plate over that is the ONLY solution. It will take somebody w/ a pretty good wire welder, with gas instead of flux core, and the welder himself will have to be pretty competent.
gearheadboy
1,425
177
84
Greencastle Pa
May 11, 2014
#10
  • May 11, 2014
  • #10
If you look close in his pic you can see he does have the top control arm reinforcements welded in already. His pics are more center of the car above that big bracket that runs side to side. The torque box reinforcements have "fixed" the problem however you still need to weld the cracks shut. You will only be able to reach them topside. The bottom is blocked by a brace. I think it is ok to drive till you have it done. The reinforcements are sandwiching it together now.
gearheadboy
1,425
177
84
Greencastle Pa
May 11, 2014
#11
  • May 11, 2014
  • #11
http://www.stangnet.com/mustang-for...ead-i-was-hoping-to-post.861248/#post-8658982
nothwoods
85
May 11, 2014
#12
  • May 11, 2014
  • #12
Just welding up the actual crack is not a good repair, I would cut out that area and either buy a replacement panel or make up some plates to weld in. Goes without saying that step one is to get the fuel tank and lines out of the way.
Reactions: stykthyn
gearheadboy
1,425
177
84
Greencastle Pa
May 11, 2014
#13
  • May 11, 2014
  • #13
Did you notice that he DID make the repair? The cracks are mostly cosmetic at this point.
R
redneck15431
83
May 11, 2014
#14
  • May 11, 2014
  • #14
Thanks again for the replies and info guys. I really appreciate it. I will provide additional pictures tomorrow to give you the entire view behind the seat. Those pics are close up and it is hard to tell exactly what everything looks like. The guy I took it to bolted them and then welded them in. He also did the lowers, and welded up a very small crack in one of them. I don't understand why he didn't do this one. But I will absolutely get it all fixed up. I don't really rip on the car anymore, it has a lot of sentimental value. I've turned just about every bolt on the car at some point. I have had it since I was 18 and I'll be 27 next month...it's my baby . I am becoming a perfectionist in my old age. The car will not move until I get the floor pan surface rust taken care of anyways. This car has no rust anywhere except there and a small spot under the hatch, where it will also be fixed before it sees any kind of precipitation. (NEVER any snow/salt though!!)
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 11, 2014
#15
  • May 11, 2014
  • #15
Killa
1,006
56
49
May 11, 2014
#16
  • May 11, 2014
  • #16
tannerc91gt said:
lol I was about to say the samething.
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
