  • SN95 4.6L Mustang Tech
What do you recommend I do for 50k miles maintenance?
  • Thread starter Thread starter 007
  • Start date Start date Mar 14, 2009
3,287
24
69
Broke
Mar 14, 2009
  • Mar 14, 2009
Car is at 48k miles after 8 years. I just got her out of my garage now that winter is done, and I'm taking her in for a service next weekend. I don't know what Ford recommends for 50k. Right now I plan on:
Oil Change
Trans Fluid (been 20k since last change)
Fuel filter (never changed)
Spark Plugs (never changed)
Just cleaned the K&N so air filter is all set.
Anything else I should do? I'm tempted to do the IAC because my Idle is beginning to wobble a little.
Thanks
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Mar 14, 2009
  • Mar 14, 2009
Rear end fluid changed Might as well while your at it. You should be good with what you listed and that. You'd probably be fine just leaving the plugs. I don't like leaving things go until the last minute of thier life cycle so i'd change them. Also a coolant flush.
3,287
24
69
Broke
Mar 14, 2009
  • Mar 14, 2009
Really? 8 years and 50k isnt a lot? I do plan to buy the Trick Flow Heads when they are finally released, so I guess I could wait and do the new plugs then...
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Mar 14, 2009
  • Mar 14, 2009
Yea i mean some guys say they are good to 100k but there is no way i would let them go that long. Go ahead and change them. I mean i've changed mine 3 times since i've had my car since Dec. 04
3,287
24
69
Broke
Mar 14, 2009
  • Mar 14, 2009
Yeah that gets me thinking though... the car runs fine and those plugs havent blown out the heads. They seem to be in there good. I might change them and then have to deal with all that crap.
If 50k miles isnt a lot for plugs then I think I'm going to wait until I get the Trick Flow heads later this year.
Just drove the Stang for the first time this year. Shes been garaged since Nov and she fired up instantly. Was great to get her back on the road again!
Killa
1,006
56
49
Mar 14, 2009
  • Mar 14, 2009
hell I change my every 10k or so NGK tr55
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Mar 14, 2009
  • Mar 14, 2009
I would do the rear diff and skip the plugs.
G
GettinThere
553
Central Texas
Mar 14, 2009
  • Mar 14, 2009
As said above, the usual oil and filter change, fuel filter change, coolant flush and refill. Although not specifically mentioned in the Ford owner's manual, a transmission fluid and differential fluid change is a good idea (I did this too). Also change the brake fluid and bleed the brakes.
Per Ford, the stock platinum spark plugs don't need to be changed until 100k miles. It's debatable whether it's worthwhile to change them at this point.
3,287
24
69
Broke
Mar 15, 2009
  • Mar 15, 2009
Thanks guys. The plugs can wait till the headswap. Added coolant and diff fluid to the list instead. Brakes were bled recently when I installed the Cobras.
blksq10psi
114
PHILLY
Mar 15, 2009
#10
  • Mar 15, 2009
  • #10
i reccomend atleast getting a 100 shot
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
Mar 15, 2009
#11
  • Mar 15, 2009
  • #11
If I were you, I'd go with:
- Fuel filter (for sure)
- Oil change
- Coolant
- Lube door hinges, suspension components
- Rotate tires? No idea if you have staggered sizes.
Thats all I would do.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
G
  • Poll Poll
I got a free Mustang from Grandma
  • GrannysMustang
  • Mar 4, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 6, 2026
Realmongo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
