What do you think of the trick flow #1 cam?
skiwesser
35
Okay, stock block .030 overbore, new eagle rods, forged K.B. pistons, Trick Flow #1 Cam (221/225 dur. @.050,.499/.510 lift), AFR 165's,I already had a Typhoon intake (I port matched to heads),73mm C&L meter, 24# injectors 42psi, 65mm TB, 1 3/4 longtubes w/3 chamber F.M. cat-back.
I want the car to be streetable so I went with a smaller cam, I like the split lift/dur. cams for a ford and I've heard they work well with nitrous which I plan to use at the strip 100-125 shot.
Does this seem like a good combo? (I tried to do my homework on it before I bought the stuff)
How much FWHP should I be making?
I'm afraid to lean it out anymore, but does the fuel press. look about right? The plugs look good not rich.
sbftech said:
its the new e303 cam
Very true. It seems to be the spot where most people start if they want an off the shelf cam.
I have one in my 93 and I think it is a pretty good cam. Of course custom is the best way to go but costs more. I would say good bang for the buck as far as cams go.
