What does a swarr bar do? Rear suspension bar I have never seen...
It would be great if I could use it as a replacement for the panhard bar.. does it work with the panhard bar? does it replace a torque are too? If not, which is better or is there a noticeable diference? These are my main questions personally.
Its nothing at all like a panhard bar. Panhard is part of the suspension that acts to keep the rear end located during turning, the swarr bar is to stop your axle stubes from bending under high HP loads.
There was a write up about it in last months 5.0 Mustang and Super Fords. Im thinking about picking one up.
To me it sounds like an alternative to welding your axle tubes.
Welding the tubes is still very important, the factory spot weld is a joke when you get a lot of power applied. The Swarr bar is just as Paul described it.
It really helps the axles from trying to wind forward as a result of a lot of HP on launches. It is something I consider standard on all drag cars, along with welding the axle tubes. I usually fab my own or I have used some other weld in kits for a 8.8 in a fox.
I have a swarr bar on my car. After I bent the housing really bad a few years ago I installed it. It has worked good ever since under some sever use. I've had my car 4 wheel aligned several times since then and it's still straight. Definitely a mandatory item if you're going to do hard launches at the track on slicks
