  • 1994 - 1995 Specific Tech
What DRs to get?
  • Thread starter Thread starter DaveB
  • Start date Start date Oct 4, 2004
  • 3
First Prev 3 of 3
Joe 5.0
1,184
Macomb, MI (metro detroit)
Oct 7, 2004
#41
  • Oct 7, 2004
  • #41
BigBlockBird said:
I just got a set of the 255/60R16 BFgoodrich Comp T/A DRs on my old 16" stockers and they improved the car a whole lot. My car has CAI, and 3:55s, and it went from a 14.5 to a 14.2 with only 3 runs. I should be able to go high 13s when I get some practice, so yea, they work fine....not overkill or anything either.
I went from 315/35/17 Nitto DR's to 255/50/16 BFG's on my stock 16's. I picked up ~1mph and 60's dropped from mid 2.0's with the Nitto's to very consistent 1.90-1.95 60's with the BFG's. That was good for ~2 tenths in the 1/4 and 2 tenths in the 1/8th.
I also run the stock wheels up front because they are ~10lbs lighter than my 17's and they are 225's vs 275's, so I'm sure the lesser rolling resistance helps. Also last time I dc'd the front swaybar (didnt remove it from the car tho) and that seemed to help a tiny bit, but not a ton.
FastGT94
300
NW Burbs, IL
Oct 11, 2004
#42
  • Oct 11, 2004
  • #42
Not trying to be a jerk here but maybe you should work on your launch a bit more first. I'm pulling 1.90's all day long on my stock radial tires (not DR's). So if you're only pulling 1.90's with your BFG's, maybe part of the problem is technique?
Again, I'm not dogging your driving, just offering a suggestion. I'm also in the market for some DR's in the future and feel your pain of not being able to hook...
Joe 5.0
1,184
Oct 11, 2004
#43
  • Oct 11, 2004
  • #43
Well do you have stock springs?
I have well over 150 1/4 mile passes and I know my car pretty well. The lowering springs really killed my weight transfer. When I was stock suspension I was pulling low 2.0's on hard as a rock BFG VR4's.
The Nitto's are more street than track tires, and dont offer very much sidewall flex at all. The BFG's are barely broken in, and every trip down they are hooking better & better. I only have 4 track days on them. Not making excuses, but our local tracks in metro detroit suck if you arent on slicks.
And to be honest I think 13.9 is pretty decent, which is what concerns me more than my 60'.
FastGT94
300
NW Burbs, IL
Oct 12, 2004
#44
  • Oct 12, 2004
  • #44
13.9 sounds about right for your combo. I do have stock springs, and I was running 14.2's before I started heavily modding and was still pulling 1.9 60' times. I could agree that track prep has a lot to do with it. If I use the other lane I'll pull 2.0's. Very strange that a track wouldn't prep its lanes the same ya know!?!
Anyways, I was just throwin out a suggestion. Also thought you were the one who started the thread
Anyways, how are those BFG's wearing for you? I'm thinking of getting a set since I only drive the car like 3-4,000 per year.
Joe 5.0
1,184
Oct 12, 2004
#45
  • Oct 12, 2004
  • #45
They seem very good so far, but I dont drive on the em other than to & from the track. I am rebuilding the trac-lok this winter and getting axles, so I might try some et streets next spring, depending on how good the BFG's hook with some LCA's.
Y
yellowstang94
11
#46
  • Oct 12, 2004
  • #46
I've got a pair of the NEW MT Drag Radials and have had poor luck with them. After talking with the tech's at Mickey Thompson I found out these tires don't work well with a 5 speed. The automatic trans is OK but they told me the standard transmission shocks the sidewall too much. I have made over 50 passes on them and can get no better than 2 tenths quicker than my street Goodyears. When I bolt on my E/T drags my 60 times are 1.67-1.70. With the Street Drag Radials the best I've seen is 1.97. I have ran the pressure all the way from18 psi down to as low as 8. Still the same...
My advise, if you have a 5 speed go to the E/T Street's if your stuck on a DOT tire.
millhouse
1,985
Simpsonville, SC
Oct 13, 2004
#47
  • Oct 13, 2004
  • #47
Which is why I will NEVER run at milan again. I can cut constant mid-low 1.8 60's with my nittos at stanton, with a few 1.7's under my belt. I struggled at milan with high 1.8 60's...and they didnt come easy.
I drive 2 hours to race in stanton, while milan is only 1/2 hour away...what does that tell ya
Even with your lowering springs, you should be able to cut 1.7 60's...just not at milan (or lapeer for that matter).
Joe 5.0
1,184
Oct 13, 2004
#48
  • Oct 13, 2004
  • #48
Thats what I've been told. I plan on hitting Norwalk next year and maybe try out stanton if I have a free weekend night.
FastGT94
300
NW Burbs, IL
Oct 13, 2004
#49
  • Oct 13, 2004
  • #49
ET streets are basically slicks as far as I've been told, and I don't need to be breaking the stock 110,000 mile rear end right now. Maybe some BFG's are the way to go for right now. The next big mod I'm planning on is a complete rear end rebuild with some 4.10's (vs my 3.73's) 33 spline axles, new trak loc etc... but $$ talks...
I know I could just be careful on the launch, but who wants to do that?
Y
yellowstang94
11
#50
  • Oct 13, 2004
  • #50
How fast ya want to go...?
How much money ya want to spend....?
Speed Cost
I don't think drag racing and being careful with a launch go together........
FastGT94
300
NW Burbs, IL
Oct 13, 2004
#51
  • Oct 13, 2004
  • #51
Exactly, I can't afford to break on the track presently so that's why I have to go slow for now lol
gcomfx.com
3,690
Republic, MO
Oct 13, 2004
#52
  • Oct 13, 2004
  • #52
Time for my favorite quote:
Cheap, Fast, Reliable
Pick two.
  • 3
First Prev 3 of 3
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
First Car Forum... EVER.
  • Godless
  • Sep 9, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 9, 2025
General karthief
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
