What else comes with Accufab/plenum combo?
spederman
732
Got a smoking deal on a used Accufab 75mm TB/Plenum that was only installed for 5 months to do some track passes. Got it for a little more than half price. I got it today via ups.
The only thing i got was the tb/plenum combo (already attached) and the extra pvc. What else comes with it? I know it should have some more gaskets, but which ones? And what about hardware, how many/which bolts does it come with? And does it come with instructions?
Last, i think i have to put the bigger pvc on it, where is the other one installed on the combo so i can pull it off and swap them?
Thanks guys.
Im in the same boat you are man. just got a used one today for $335. from what I understand there are no instructions. I dont know anything about a new PCV, is that something I should order? I know we're supposed to use a voltmeter to check the TPS at idle, and it should be between .98 and 1.00. exactly how, I dont know. The guy also told me there is no gasket between the plenum and intake manifold. also he said you just re-use the stock hardware. if this is all true, im not sure. hope it is though bc all I got was the plenum/TB.
it looks pretty straight forward but I dont want to screw something up and have idleing issues. I posted a thread over in talk. if I get some answers I'll shoot them your way. do the same for me? I'd appreciate it. enjoy it man, quality looks excellent :nice:
Here's something about adjusting the TPS from Accufab.
Accufab's Website said:
After installing the throttle body, the Throttle Position Sensor (TPS) will need to be adjusted.
Adjusting the TPS to the correct voltage is not difficult. It will require use of a Digital Voltmeter and a correctly sized screw driver.
The TPS is a small black plastic device affixed to the throttle body with two screws, and located on the opposite side of the throttle cable linkage. The end of the throttle blade shaft is machined to fit into the TPS. The TPS is electrically connected (with a quick disconnect plug) to the main wire harness. The TPS is in essence, a low voltage potentiometer or resistor. It provides input data to the ECM (computer) regarding the position of the throttle. The TPS supplies a gradually increasing supply of voltage to the ECM as the throttle is gradually opened. How the ECM processes this data depends on other prevailing conditions, including engine speed, load, vehicle speed, engine and ambient temperatures, and so on. The information from the TPS is especially critical for proper start-up and idle, as well as smooth throttle response. An incorrectly adjusted TPS may be most notable by an idle speed that is either too fast or too slow. The proper idle speed should be between 750 and 900 RPM, and will be dependent on different engine combinations, particularly with engines that may have non-stock modifications.
To adjust the TPS, please refer to the following:
Disconnect the ground cable from the battery.
Remove the TPS from the original throttle body and install it on the new Accufab throttle body. If new screws have been provided in the package from Accufab, use these screws (they are shorter). If not, reuse the original or stock screws.
Reconnect the TPS to the wire harness.
Reconnect the battery.
Now, the TPS needs to be adjusted to achieve the correct voltage at idle. Changes to the idle speed can ONLY be made by adjusting the TPS.
DO NOT ADJUST THE STOP SCREW ON THE THROTTLE BODY UNDER ANY CIRCUMSTANCES. This screw has been pre-set at the factory to insure a proper air gap around the throttle blade in the fully closed position. If by chance this stop screw has been adjusted in the field, please call our TechLine for further assistance.
The TPS is connected to the main wire harness with three separate, color coded wires:
Gray & Red
Gray & White
Brown & White
The gray & red wire is the ground wire (could also be a black wire).
The gray & white wire provides the voltage information to the ECM (could also be a green wire).
The brown & white wire provides a 5-volt reference signal WITH THE KEY ON (could also be an orange wire).
If you have any problems identifying the different colors or if the wires are different colors from those described, check inside the plastic quick disconnect plug. The plug connection tangs should have an “A”, “B”, and “C” next to each tang.
A = gray & red wire
B = gray & white wire
C = brown & white wire
Because of the different suppliers of TPS’s, and the potential for different wire colors, you may need to “poke around” on the wires in order to determine the positive and negative leads. An easy way to take voltage readings is to stick a safety pin through the individual wires, and then make contact with your Volt Meter probes to the safety pins.
To check voltage, THE IGNITION KEY NEEDS TO BE IN THE ON POSITION BUT THE ENGINE MUST NOT BE RUNNING. With the positive (+) lead from your voltmeter, pierce the gray & white wire. With the negative (-) lead from your voltmeter, pierce the gray and red wire. The voltmeter should read no less than .98 volts nor more than 1.0 volts. If the voltage is too high, loosen, but do not remove, the two screws holding the TPS to the throttle body, and rotate the unit counter-clockwise, until the voltage is correct. Rotating the unit clockwise will increase the corresponding voltage. When the voltage is correct, retighten the two screws. The only adjustment is the “slop” between the inside diameter of the holes and the outside diameter of the screws, so we are dealing with just a few degrees of rotation.
The Ford ECM’s are very unforgiving when it comes to ANY engine modifications from stock. The addition of an Accufab throttle body should not have any negative effect on idle speed, off-idle performance (tip-in) or the RPM returning to idle speed, within a second or two, when the throttle is closed.
If on the other hand, modifications to the stock engine include additional supercharger boost with the use of different supercharger pulleys (particularly noticeable on supercharged 2003-2004 Mustang Cobra’s) or adding a “re-programming” chip or add-on computer module, the standard TPS voltage readings and other drivability issues may be noticeable, and could include an overly fast idle and a resistance of the ECM to “allow” the throttle to close properly, resulting in a delay between removing your foot from the gas pedal and the engine returning to idle.
These are not throttle body problems. The throttle body is a mechanical device with only one moving part. As long as the throttle body slams shut when you close the throttle (key off, engine not running), the throttle body is functioning correctly. Any other problem is associated with the ECM and the feedback it is receiving, either due to the increased boost at idle (more air supply) or the add-on computer chip sending incorrect (or unknown) data to the ECM.
Helty,
I found some nice write ups about install with pics on stangpro.com. So with that write up and your info on tps adjusting, it should be pretty straight forward. The write up on stangpro also used all the stock bolts for everything. So we should be good there. The only thing i did find out is that the tb/plenum comes with new IAC and EGR gaskets. So we might need to pick up new ones if the stock ones are unusable. Hopefully Ford doesnt screw us on those. I dont know if you'll need that adapter thing for the PVC that i got. Hopefully somebody can help us out with that. In fact, i dont even know what to do with it. I'll keep you updated.
cool man, thanks. I'll go to the ford dealership and order those gaskets tomorrow. thats probably a good $40 but what the hell you know?. I know nothing at all about a PCV adapter. hopefully someone that has done this will chime in and enlighten us.
I think it came with a egr gasket too. If Im not mistaking the egr gasket it came with is thicker than the flimsy stock one. Mine did not want to seal up with the stock gasket. So I used the one from accufab.
Helty,
I think that PCV adaptor is for some particular years. I have an '03 and didn't need it. I don't remember what year and I don't have the instructions anymore to look it up, but I still have the adaptor. If you need it, let me know.
Mine came with a gasket, but I didn't use it. Not sure if I saved that.
