What else do I need for a Fox TB Swap?
zZsKyZz
503
What else do I need?
Throttle cable from a fox car, EGR spacer or delete plate, cruise control cable (optional), Studs or bolts for mounting everything, and new air inlet.
Don't forget the wiring of the TPS. . .
Seeing as you have the fox EGR valve, I would assume that you want to go with the fox EGR route. In which case, you need to either put a cap on the header bung for the EGR tube (fox's run an internal EGR) or run fox headers.
