What else do I need to order?
tack_78
87
I am about to order the following.
Autometer cluster gauge pod, Autometer dual A-piller gauge pod, Autometer Phantom gauges, Electrical Oil Temperature 100-250 degrees, Mechanical Fuel Pressure 0-100psi, Mechanical Boost/Vacuum 20psi, Mechanical Air/Fuel Ratio.
I will be adding a Kenne-Bell Intercooled 9psi kit within a couple of months and want to have these installed already. Is there anything else I will need in order to hook these up? Or should I maybe order some different gauges? Thanks for all the help.
