  • SN95 4.6L Mustang Tech
what engine do i have?? please help!!!
  • Thread starter Thread starter 98WhiteGT
  • Start date Start date Nov 6, 2004
9
98WhiteGT
Plano, Texas
Nov 6, 2004
  • Nov 6, 2004
ok, i have a 98 GT. Recently my engine "threw a piston" or something to that effect, so they had to replace the engine. It was done through a warantee company and so they said that they put in an engine from a 2001 GT i believe. so i need to know how to tell if this is a 99+ motor or if it's from a 96-98????
TweekedGT
1,274
Alberta
Nov 6, 2004
  • Nov 6, 2004
Have you had a chance to drive it? You would notice a difference in power right away. It will be a totally different car. As per how physically you can tell it will be very hard. i can't tell the difference since my head swap by looking other than it is newer. There must be a serial number stamped on the block somewhere. If you can find it i would phone it into a ford dealership and ask them. I may be wrong but it's worth a shot.
9
98WhiteGT
Plano, Texas
Nov 6, 2004
  • Nov 6, 2004
dunno
i can't tell on the power, due to a "popping" noise and a new clutch i've been babying it around, so i haven't gotten into the power yet--see here-- Other forum post--POPPING
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 6, 2004
  • Nov 6, 2004
PI intake?
CanadaStang
2,093
Mb
Nov 6, 2004
  • Nov 6, 2004
Take a look at the intake. Measure the distance from the bottom of the intake to the bottom of the valley [top of the motor between the valve covers] if it hangs down quite low, then it's a pi, if there is a lot of space then it's non pi.
Nuar
570
NB, CT
Nov 6, 2004
  • Nov 6, 2004
Correct me if i'm wrong (i dont think i am) but dont the 98 and older stangs have Spark Plug WIRES?
99 and up stangs use coil on plug setup, elimination the plug wires....
CanadaStang
2,093
Mb
Nov 6, 2004
  • Nov 6, 2004
Yup, your right, but I believe the coils have to be switched over from the old motor, same as the fuel rails.
C
98 mustang keeps popping at idle like popcorn please help
  • Cannron
  • Aug 14, 2025
SN95 4.6L Mustang Tech Aug 14, 2025
squeak93
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
