What engine do I have?
  • Thread starter Thread starter cherokeetrinity
  • Start date Start date Sep 28, 2009
C
cherokeetrinity
49
  • Sep 28, 2009
the heads are stamped DOVE-A2A, which motors did they put them on
6Stang7
1,470
Livermore, CA
Sep 28, 2009
  • Sep 28, 2009
I don't have the book I need at hand at the moment, but if my memory servers me the D0VE means that you have heads from a 1970 Lincoln engine. I'm not 100% sure what the A2A means, but I believe that it means that they are from a 460.
boomer300
15
  • Sep 28, 2009
1970 429 or 460 heads with smaller combustion chamber vs post 72 larger chambers (I BELIEVE). I also don't have my book here.
kilgorq
77
Boise Idaho
Sep 28, 2009
  • Sep 28, 2009
D0 = 1970
V = Lincoln
E = Engine Group
A2A = I think that is the Big Block head part number
kilgorq
77
Boise Idaho
Sep 28, 2009
  • Sep 28, 2009
Not sure how accurate but this is what I found on another forum.
D0VE was 77CC
D3VE was 97CC .
D0VE heads have a stud rocker system
D3VE heads have a slotted pedestal/sled rocker system.
And there are minor differences in the exhaust port size.
Also D0VE-C have the largest ports available on the Stock 429-460 heads.
D
D.Hearne
11,730
south louisiana
Sep 28, 2009
  • Sep 28, 2009
DOVE heads were the std heads for the 70-71 429/460's. Screw in studs and small quench chambers. Have em fitted with the CJ sized valves and ported to match CJ ports and you've got an excellant set of heads. The studs will also need to be replaced with non positive stop studs and the bosses milled to accomodate guide plates for bigger cams.
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
