What engine is this?
  • Thread starter Thread starter danewers
  • Start date Start date Sep 28, 2005
danewers
97
  • Sep 28, 2005
Ford V8 5.0 HO engine
this car is local, but i'm pretty sure this isnt the engine that came with the car. i'm pretty sure it came out of a mustang. if so, how can i tell if its from a 89-92 mustang gt and if it has a MAF sensor? I couldnt see one in any of the pics. I'm going to go check the car out this weekend, but my main concern what year the engine is and if it has a MAF sensor, and how i can check the engine to see what year it is. this is going to be for my 347 stroker project. any help is appreciated. thanks!
89stangWhiz
104
Mechanicsville, MD
Sep 28, 2005
  • Sep 28, 2005
well the vin should give away the year if you can read it. I'm not sure of them but the lookup codes should be easy to find.
Thats my engine, a 5.0 HO, mine is an 89.
ss93cobra
1,422
Wilmington NC
Sep 28, 2005
  • Sep 28, 2005
Look at where the a/c lines go to the a/c compressor. Looks more like orginal lincoln style vs. factory mustang style. Aside from the fact that the car did indeed come from Ford with a 5.0 h.o. in it.
danewers
97
  • Sep 28, 2005
where would i find the VIN on the engine? also what are the lookup codes?
either way i'm thinking this will be an excellent doner engine to start off with.
ss93cobra: if they did swap the engine, i'd be guessing they kept the original lincoln AC lines and compressor and just bolted it up to the new engine.
danewers
97
  • Sep 28, 2005
also do you see a mass airflow sensor? i don't think i see one but i can't be 100% sure from the pic.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Sep 28, 2005
  • Sep 28, 2005
like ss93cobra stated those cars did indeed come stock w/ 5 liter motors.if your building a stroker what diff would it make if it was mass air or not?that maf is going to be way to small to support that monster.if your looking for the wire harness than i can understand.im not sure about the lincolns but all post 88 5 liters were mass air.
danewers
97
  • Sep 28, 2005
yeah i mostly want it for the wiring harness and computer. i know the lincolns came with 5 liter motors but i thought the H.O. was exclusive to the mustang? thanks for everyones help so far!
95opal
5 Year Member
Nov 16, 2004
449
20
39
Sep 28, 2005
  • Sep 28, 2005
nope not exclusive.
danewers
97
  • Sep 28, 2005
wow i didn't know that. thanks for the education! haha. so we're all H.O.'s pretty much the same (internally, like same heads, pistons, cam, etc), regardless of which car they went in?
ss93cobra
1,422
Wilmington NC
Sep 28, 2005
#10
  • Sep 28, 2005
  • #10
All internals should be the same from 5.0 to 5.0 except for the piston change in the 92-93 era. Regarding the mass air, it should be mass air equipped given the model year, but its hard to say what could have been over the years. Mass air sensor is not in the picture by the way. Pic. is not far enough forward...
95opal
5 Year Member
Nov 16, 2004
449
20
39
Sep 28, 2005
#11
  • Sep 28, 2005
  • #11
nope some had diff heads like 85,86,87-95 diff cam specs too,not sur of the diff year specs.piston changes were also made diff years some had the crappy hypertech pistons(crappy depending on application,if boosted crappy.)
im sure some one else can help w/ other differances and expand on what ive mentioned.
Lyncher
434
#12
  • Sep 28, 2005
  • #12
Jest to elaborate I believe that only the 93's had the hypertech pistons
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
