So what should i set my fuel pressure to? It is a "WET" kit. I have read anywhere from 40 to 50 psi but that was not mustang specific. If it helps I will be starting with a 50 shot and then working my way up to a 100 shot.
I have everything hooked up except a msd window switch, FP safety switch, micro switch, and relay. Once I have these things I will be ready to spray.
I was wanting to do some testing so I hooked up a button to the fuel sylenoid and then turned the fuel pressure to 48 psi vacuum line off. I took it for a drive and hit the button at 3k rpm's @ WOT to simulate spraying. I watched my fp gauge. It instantly dropped to like 30 psi for only a split second and then it went right up to 48 and stayed there. Is this normal for it to drop for less than 1 second and then jump back to where it should be?
I posted this in the "power adders" forum as well but since there isn't very much traffic in there i thought i would post it here as well.
:SNSign:
:SNSign:
