Try this... Currently there is some dispute about setting it at .99 volts but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks. Set it at .97v-.99v, the closer to .99v the better.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn. Then you adjust the TPS voltage to .98v, reset the computer. Start it up, if the idle is to low then turn the screw in until it is just right, then readjust the TPS voltage to .98v and reset the computer and start it up. The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
