  • SN95 4.6L Mustang Tech
What fuel pump?
  • Thread starter Thread starter astronut1885
  • Start date Start date Jan 20, 2008
1 of 2 Next Last
astronut1885
1,899
Assonet, MA
Jan 20, 2008
  • Jan 20, 2008
Hey guys. I have an 04 GT which will be getting a FRPP roots style blower strapped on soon. What I need to know is which fuel pump to get. I'm probably going to be around 300 RWHP in the near future, and over time will add more mods to an end goal of around 400RWHP. I want a fuel pump that is more or less a drop-in, swap replacement and will cover these power levels. I've heard things about a SVT focus pump, and the GT supercar pump, but don't know enough yet. Fill me in.
lvmustanggt
721
Las Vegas
Jan 20, 2008
  • Jan 20, 2008
SVT Ford focus pump will be enough and it's a easy install with no mods needed .
Tim2002GT
635
Tulsa, Oklahoma
Jan 20, 2008
  • Jan 20, 2008
^ I agree.
BennyBlown2v
1,233
Carmel, INdiana
Jan 20, 2008
  • Jan 20, 2008
Yeah focus pumps are great for the price. Heck, I picked up two of them for $75 shipped a while ago, hah.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 20, 2008
  • Jan 20, 2008
Hope you've already got the blower. Last I heard, FRPP doesn't make them anymore.
*NEVERMIND*
I just notice the bottom of your sig.
SilverBullet00
1,150
Wichita, KS
Jan 20, 2008
  • Jan 20, 2008
Id go straight to the 03/04 cobra pumps and tank. I Maxed my focus pump out right away. I got mine for 500 shipped w/ a NEW tank and used pumps. Look around for awhile and you can find a good deal.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 20, 2008
  • Jan 20, 2008
if you'renot going over 400 hp (and you're not on the FRPP blower) a focus pump will be the way to go. make sure it is an SVT focus pump. there is a differance
astronut1885
1,899
Assonet, MA
Jan 20, 2008
  • Jan 20, 2008
Yeah, I'll be sure to get the SVT version.
SB: While that is a choice setup, it's a little overkill with my current plans. Down the line, when i find some way to push my little blower to 500, that's the route I'll go. And I will find a way, whether it means porting the blower, sick heads and cam, a stroker, whatever it takes, I eventually want to be the only guy making 500/500 to the rear wheel on a FRPP roots blower.
astronut1885
1,899
Assonet, MA
Jan 20, 2008
  • Jan 20, 2008
http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEWA:IT&viewitem=&item=260196687875&rd=1
is this the right one?
the98stang
2,408
Clovis, CA
Jan 21, 2008
#10
  • Jan 21, 2008
  • #10
do it right the first time....buy a cobra tank w/ pumps. It's worth the money.
SilverBullet00
1,150
Wichita, KS
Jan 21, 2008
#11
  • Jan 21, 2008
  • #11
Its crazy man, some people max the focus pump out at 360HP, and some max it out closer to 450. If you run a single pump, then I'd say get the ford GT pump (which is cheaper than the focus) and modify the basket.
RandyStinchcomb
1,159
Randallstown, Md
Jan 21, 2008
#12
  • Jan 21, 2008
  • #12
it is but I've seen them cheaper and wth a warranty too
astronut1885
1,899
Assonet, MA
Jan 21, 2008
#13
  • Jan 21, 2008
  • #13
What has to be done to run the Ford GT one?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 21, 2008
#14
  • Jan 21, 2008
  • #14
you will not need anything more than the focus pump. it is a direct drop in
astronut1885
1,899
Assonet, MA
Mar 31, 2008
#15
  • Mar 31, 2008
  • #15
http://cgi.ebay.com/ebaymotors/ws/e...STRK:MEBI:IT&viewitem=&item=220218792310&rd=1
I threw a bid at this one, it's Steeda's upgrade pump. Here's what they say about it: http://www.steeda.com/products/replacement_fuel_pump.php
That should be able to handle the roughly 100HP I'll be adding. By the time I'm done with the car I plan on needing a Cobra setup, but I think for now with a bolt on car with exhaust running 6 psi through the FRPP blower with meth and 30# injectors, that thing should do the trick. Opinions?
G
GettinThere
553
Central Texas
Mar 31, 2008
#16
  • Mar 31, 2008
  • #16
astronut1885 said:
...What I need to know is which fuel pump to get. I'm probably going to be around 300 RWHP in the near future, and over time will add more mods to an end goal of around 400RWHP. I want a fuel pump that is more or less a drop-in, swap replacement and will cover these power levels...
Maybe start out with the SVT Focus fuel pump, and add the Kenne Bell Boost-A-Pump later if needed?
blkhorse
345
Mar 31, 2008
#17
  • Mar 31, 2008
  • #17
I am going to run the gt pump with a bap and wiring upgrade. plenty how to's if search here and other sites. the modification necessary to run the gt pump is not hard or anything and it puts out more lph than the svt focus and cheaper too. this setup should be good for around 475rwhp,beyond that you will need dual pumps etc. Right now with mods in sig.I am maxed out on the stock pump with a bap. if you plan to run a single pump,I suggest a bap also
astronut1885
1,899
Assonet, MA
Mar 31, 2008
#18
  • Mar 31, 2008
  • #18
How difficult is installing a BAP? Does it need electronics, or is it just an "on/off" application?
blkhorse
345
Mar 31, 2008
#19
  • Mar 31, 2008
  • #19
real simple to hook -up,it is electronic. some people wire it so it's on all the time,I run mine with the hobb's switch provided so it comes on at about 2 psi boost. go to Kenne bells website and you should information there
astronut1885
1,899
Assonet, MA
Mar 31, 2008
#20
  • Mar 31, 2008
  • #20
I was just looking at it. So could I combine that with the Steeda pump and get it done? I wouldn't mind doing that, because the BAP I'd use would also be compatible with a stock 03 Cobra style setup that I may go to down the line when I get heads and cams and such.
1 of 2 Next Last
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
