  • 1994 - 1995 Specific Tech
What gauges to get?
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Nov 1, 2004
91LX_5L
1,943
British Columbia
Nov 1, 2004
  • Nov 1, 2004
I have H/C/I, TB, MAF, hope to get a adj fuel reg soon.
I just bought a lunar 5" tach and a water temp gauge, and am going to get a oil pressure. I was thinking a air/fuel as well or what should I get?
How hard are these to install? Is the air/fuel pretty difficult?
Thanks!
95BLKGT5.0
608
Auburn Washington
Nov 1, 2004
  • Nov 1, 2004
Yes get a oil pressure and air/fuel also you could get a volt meter.
Then do some custom mounting.
I have a Saleen dash pod with auto meter carbon fiber gauges water temp and oil pressure.
I also have a plate that I covered in black leather that mounts in the spot under the radio for air/fuel and Boost (for when I get a supercharger).
As far as installing just take your time read the directions and plan on most of a day to do it right. Having someone to help feed wires thru the firewall helps.
91LX_5L
1,943
British Columbia
Nov 1, 2004
  • Nov 1, 2004
thanks CHECK YOUR PM!
94TURBO5 O
2,509
VA
Nov 1, 2004
  • Nov 1, 2004
Do yourself a favor and get an fp gauge instead of an a/f one. Unless it's a WB o2 then it's not going to read accurately at all.
Numbles
998
Chicago, IL
Nov 1, 2004
  • Nov 1, 2004
OT questoin but it doesn't need a new thread.
Why do people say that stock 02's are too inaccurate to use an A/F guage for. Or better yet, why are they innacurate at all. I remember reading that a WB o2 can read from 0 to 20 on a/f. Whereas a stock one can only go from 10 to 15.
Definately get the oil and temp guages though.
HISSIN50
34
129
Nov 1, 2004
  • Nov 1, 2004
agreed.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Nov 1, 2004
  • Nov 1, 2004
dont get a a/f gauge unless you just want to see a pretty light show at night get coolant temp and oil pressure
91LX_5L
1,943
British Columbia
Nov 3, 2004
  • Nov 3, 2004
so you think just a coolent and oil pressure will be all I need?
electrical gauges are fine right? can you mix the two (one electrical and one mechanical)
HISSIN50
34
129
Nov 3, 2004
  • Nov 3, 2004
those two are the most important, IMHO. others are nice, but if you can only have two (or two for now), those would be my choices.
mechanical voltmeters dont work very well. J/K.
sure you can mix and match mech and elec gauges. good luck.
91LX_5L
1,943
British Columbia
Nov 3, 2004
#10
  • Nov 3, 2004
  • #10
ill just get electrical...what other gauges might be useful for me?
HISSIN50
34
129
Nov 3, 2004
#11
  • Nov 3, 2004
  • #11
since i think you mentioned an AFPR, i would get a FP gauge. your choice of what flavor you get (be careful when choosing if you are going to mount it inside the cockpit. you need an isolator, etc).
importance to me (different for everyone): oil pressure, water temps, volts, oil temps, FP, vac. i dont rev much so a tach is not important. the O2 gauge looks nice - you just tap into the ECU harness. if running only one gauge, get a toggle switch to go from bank to bank.
i have a fox, so im not sure how much more accurate your gauges are than ours. there is one guy with 16 aftermarket gauges over on the other side (5.0 tech). LOL.
ill also mention that one can get full sweep electric gauges, though they are $$. i like mech gauges myself, and one reason is the full (270* sweep).
all for now. good luck.
HISSIN50
34
129
Nov 3, 2004
#12
  • Nov 3, 2004
  • #12
but i would recommend an electric oil-pressure gauge. that way if there is a line failure, you dont have hot oil squirting inside the cockpit.
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
