what gear ratio do i have
if you think you may have something better in there, then what you can do is jack the rear end up, and put a chalk mark on the driveshaft. Then turn a rear wheel one complete revolution and count the number of revolutions of the driveshaft. So about 2 and 3/4 turns of the driveshaft would be 2.73s, 3 turns would be 3.08s, 3 and 1/2 would be 3.55s etc etc - you get the idea.
BTW, the axle codes are all listed in Chiltons.
Howard
That's the best way. If the speedo hasn't been corrected, then using the factory tach & speedo will not tell you that you have different gears. Have to use a GPS for the same trick.
Corral has a calculator for this kind of stuff, as well:
http://www.corral.net/tech/gearcalc.html
Dave
