What gears?
dave96stang
31
SoCal
I bought my 96 gt used last August and my question is, How can I tell what kind of gears are in my car? I don't know if my rear end is stock or aftermarket, it seems like when I make fast turns my rear end comes around, which is what everybody says is a symptom of having a higher gear ratio. Is there a way to tell?
[QUOTE='96&'01Stang]How will the spider packet mess it up? What is a spider packet[/QUOTE]
Have you ever wonderd why when you jack your car up and spin one of the wheels, the other spins in the oppisite direction? That is because of the spider packet (what I was tough to call it at least) which is made up of two pinion gears and two side gears. I have no idea how to discribe it to you in words, so your best bet is to just go here, they have some great pictures that you should help you understand. http://auto.howstuffworks.com/differential.htm
-Shaun
-Shaun
Sorry, I've never wondered that. Probably because both of my Mustangs have had a Track Lok limited slip. Limited slip cars won't do that, unless the clutches are completely shot. :D
6Stang7 said:
That will not work because the spider packet will mess it up. You're better off doing what forpit2000gt said.
-Shaun
Not true. A limited slip axle (which I believe all GT's come with standard) uses clutches to tie the axles together and make them turn the same speed, thus also preventing them from turning the opposite way like an open diff would.
Here's one way to tell:
http://www.corral.net/tech/gearcalc.html
Your car most likely has one of three different ratios, assuming that the rear end is stock.
2.73
3.08
3.27
Hope this was some help.
