What heads for nitrous
blacksleeper
This qeustion is for one of my buddies. He wants to know is it safe to run aluiminum heads witt a 150-200 shot of nitrous or should he stay with cast iron heads?
Also which nitrous should he run on a small block dry or wet system. It's a carbed motor. Thanks for ya'll help.
Aluminum heads will be better actually. Thicker decks and and better heat disipation. I didnt know that there was a dry shot kit made for carbs? Wet would be better in the long run any way. Maint thing is to make sure you have plenty of fuel for the hp you want to run. I used to always go up one size on my fuel jets from what the calculator said just to be a little safe. If you have a wideband, then you can further refine it.
