I have been debating and researching for the past 4 days and I can't make a decision between the MM Extreme Duty and Heavy Duty suspension components. What is the HP that you have to have where Heavy Duty no longer cuts it and you need Extreme Duty? I have the mods in my sig, and I plan on getting 3.73's then spraying it with 100-150 wet shot with possible HCI in the future...
Would Heavy Duty LCA and FRPP UCA with new bushings cut it? Or should I look into getting Extreme Duty LCA instead?
Also, this car will mostly be a street car but I will be taking it to the track aswell and I will want to be able to run slicks, I was told the ajustable arms are used for running taller tires but I am not sure if I will need the ajustability or not, what are your opinions on that?
Thanks for all your help! Hopefully I can make a final decision on what rear setup to go with before I really put some life into the engine.
