Since you own a '94 I would suggest you maintain as much low end as possible because the 94 & 95 weigh a bit more than our 87-93 cars
I assume you are gonna stay with the stock engine displacement (302ci)?
Well with a 302 and 165's, you are probably gonna run a good, but emissions acceptable cam, right? It sounds like a daily driver car to me.
In which event I suggest the GT-40 ... it looks the best (IMO) and you won't lose any low and mid range power ... plus it pulls a lot better up top compared to the factory intake.
You gotta ask yourself why this is the intake that all aftermarket street pieces are compared to ... well, because it is a real good runner and will support up to 400 flywheel horses n/a
Also I imagine you are going to run a 24lb injector? ... in which event there is no need for an intake which will support tons of air flow.
165's are an idle to 5800 rpm head, unless you get them with the upgraded (stiffer) springs to allow the engine to rev higher with matching parts.
Grn92 suggests the RPM intakes, but those intakes favor a bit more top end at the expensive of bit less bottom end power .... plus most of the time street cars are driven in low and mid range anyway ...
I have an RPMII on one of my cars and it works really well, but the car has a 331 (which pulls more air) and is well matched on it's speed parts.
The BBK I have never seen in action, but when tested (in 5.0/SF magazine) on a 302 with 165's it had an erratic power curve ... the writer felt it needed more airflow ... and so when they strapped it on a 347 the erratic curve went away and it did really well making top-end power ... but they still called the GT-40 the best all-around intake of the test for a street car.
