I've seen kits that place the alternator on a swivel. Then you can use the alternator as the tensioner and toss that huge, heavy bracket thing and run a short belt. Even MORE weight savings and complexity reduction. Those idler pullies are the stupidest things I've ever seen! The idea is to REMOVE things from the car to make it lighter, not replace a useless piece of equiptment with another even more useless piece of equiptment. That idler pully does have some tiny amount of drag associated with it. It's not a freebie. Pull the pump, stick 2 RTV covered bolts into the back of the heads where the crossover airtube is, another into the airfeed tube on the cats and you are done. About 20 pounds gone. Go with the alternator swivel mount for even more weight loss.
