Engine What is the best way to lift lower intake off?
silverlx50
168
62
38
I am trying to swap my Cobra intake for a Systemax. I cant lift the lower intake manifold up, like at all. I have removed all the bolts and stud so it's just RTV holding it down. I used a pry bar once on an old lower and broke the front of the intake at a thermostat housing so I dont want to do that again. Any suggestions?
Use a razor blade to cut the silicone front and back,take at least one v/c off,and pry with flathead screwdriver from side v/c is off.Good hunting Will.
I've never had one come off either. In fact, my last one lifted up by hand once I removed the last bolt. I also use minimal RTV. No leaks on that one either.
I'd probably put a prybat under the therm neck and lightly apply pressure while whacking it with a dead blow.
