what is the Canp?
Sazxus
10
On the salt and peoper shakers. what is the Canp?
I have a orange wire coming from the white shaker in the location of the Canp (10)...it looks to have been cut at some point.
Just want to know if i need to find it a home or if its ntohing to worry about.
Thank you .
Makes perfect sense to me...
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
For more help, see http://fordfuelinjection.com/?p=6.
sirsureshot39 said:
wtf is going on in here? Whos salt and pepper shakers? Someone talk some damn english.
See the attached photo courtsey of Tmoss & Stang& 2birds. Notice the black & white 10 pin connectors, also known as "Salt & Pepper shakers"
