What Is The Proper Belt Lenght To Eliminate Smog With A/c??5.0l
I made the same offer to somebody else-
If nobody can help you, let me know, I have a diagram [with belt lengths] that I can Fax you....I might have it as a picture on the computer as well. I get home @ 5:00pm PST. Let me know....PM me or post something here.
I Am Wanting To Remove It Because I Am Running No Cats Shhhh And Because I Am Getting A Backfire When I Shift Passed 5000 Rpm??? I Am Thinking Because The Air Pump Is Pumping For Nothing Or???suggestions.
I doubt the smog pump is causing your backfire. Since you're not running cats, the smog pump probably isn't even running to your H pipe. However, if you don't have cats and don't live in a state w/ testing, might as well pull the smog pump....might not be a bad idea to keep it back though "just in case" you need it later
Power steering pump too
If you do route around the power steering pump, does that mean you have to replace it with something else for a steering box or something, or what kinda work is it to do to do this? Also what kinda gains do you expect from doing something like routing around the ps pump, I already route around the smog pump?
